Guys
I have a late production 69 that may be a L46; in the absence of a build sheet, I am curious if this scenario can be used to verify the L46.
VIN VIN 194379S736819 Trim Date P23
Rear code 1CAO11 24 69
Notice that the CAO code is indicated to be used with HP350 and M21.
It appears to be common knowledge that late 69 production started to use some of the 70 codes, parts, and assembly methods. The problem is my block is the correct 3970010 but is cast F73 and the stamp pad is void of any stampings and has what appear to be factory broach marks leaving me to suspect it has not been decked (not that it matters because of the date code). I have the VIN stamped correct M21 and every single thing checks out to make this an L46 car expect for the 5300 redline tach which of course could have been replaced incorrectly. I have what could be the original correct heads, pulley, console call out; but lack that certainty because of no build sheet, tach, and block. I would like to know opinions if the rearend code can lock down the fact this is an L46 car.
Also if this 70 ordering flow chart is accurate; is it also applicable for 69 concerning the base and L46 rear end options? If so; this as well should lock down the L46 on my specific car.
