60 283 questions - NCRS Discussion Boards
60 283 questions
  • Dick G.
    • May 31, 1988
    • 681
    60 283 questions
    I picked up an old 283 engine on Friday. It was a giveaway. Block is a late 60 #519, dated L280. Won't work for my June car. Trading stock. Anyway, the harmonic balancer is pressed on with no threads in crank to hold on balancer. The only cast number on this crank is 218. Is this an earlier crank? Shouldn't a 60 crank have a threaded hole on the end of it's crank for a bolt to help retain it's balancer? If I remember correctly, my 57 had a pressed on balancer. No bolt. My 60 was a 270HP originally, and will be again. Also, The waterpump number is a 3859328 dated F118. Where was this pump used? Heads are late 462624. Dated D29 and C298. Are these 78-79 heads? Boatanchors? Only problem is, I got rid of my boat years ago. If anyone can decipher these numbers, Thanks. Joe Lucia where are you?
    Dick Gutman 13180
  • Mark P.
    • May 13, 2008
    • 951
    Re: 60 283 questions
    The 1960 283 did not have a threaded snout for a bolt. I had a machine shop add that when I rebuilt my 1960 283 six months ago. It made the HB install easier and I have the piece of mind the bolt provides. I ran into trouble getting a HB that had the right interference fit. The first 3 I tried were all slip fit. Don't know how many times these can be installed before they get stretched.
    • Dick G.
      • May 31, 1988
      • 681
      Thanks Mark
      DG
      • Dick G.
        • May 31, 1988
        • 681
        I found the cast number on the crankshaft and located it in a book of mine. 3735236 is forged for 55-62 283. DG
