Dulling Down Urethene Paint - NCRS Discussion Boards
  • Bill O.
    • April 1, 2006
    • 542
    The Vette lost some points at the Wisconsin Regional on Paint....specifically, too much gloss below the front and rear bumpers, near the bottom, and around the fender margins. Fortunately, I had taken Scotch-Brite scuffing pads and some light work with rubbing compound to door jams and trunk and hood gutters, and that turned out very well. And I'm sure I can get the same effect at the fender margins.
    But I worry that with a larger area with no break, even though its lower to the ground, I won't get an even reduction of the gloss. The car is white.
    Does anyone have any ideas how to do this and make a decent job of it, short of a new paint job.
    Thanks for any suggestions you have.
    Bill
  • Bruce B.
    • May 31, 1996
    • 2930
    Re: Dulling Down Urethene Paint
    I have been told that you can spray the area with some "hair spray" and it will have a dull appearance. After judging it can be washed off.
    There also some matte finish or semi-gloss clear coat aerosols which will dull the area but I believe it is permanent.
    • Harmon C.
      • August 31, 1994
      • 3228
      Leave it alone and take the hit if it won't effect the bottom line. This is an area where you think you fixed something and the next judge has a different idea. The next judge may not say a word about that area and takes the same deduction for some other reason. Paint is hard to judge and no two judges see it in the same light.
      Lyle
