C-2 front end alighment shims - NCRS Discussion Boards
  • Dale S.
    • November 12, 2007
    • 1224
    My 67 has no tab on the front end alighment shim to help remove them (I guess that is what the tab is for). They are just flat across the top. Someone is advertising on ebay for front end shims with tabs as being correct for 1967. Are my non tabbed shims incorrect? They have been there since early 1971 when I bought it. I can not imagine anyone changing them all. Thank you Dale
  • Ken A.
    • July 31, 1986
    • 929
    Re: C-2 front end alighment shims
    They are incorrect. Originals were "tabbed" and still available. Just buy a handful of assorted sizes, match up to what you've got, & install.
    • Gene M.
      • April 1, 1985
      • 4232
      Dale, the correct shims for 67 are square off flat tabs. The incorrect round tabs with a hole are in common use by front end alignment shops.
      • Stephen L.
        • May 31, 1984
        • 3159
        Dale,
        Front end alignment shims had a tab but NO hole.
        Shown in photo below.
        Shims used at core support had no tab. Flat across top
        I can imagine that both types may have been used.
          • 43242
          Dale-----
          Attached is a photo of a correct, original shim. There were 3 different thicknesses used----1/8", 1/16", and 1/32". Is it POSSIBLE that some cars originally used alternate configuration shims? Yes, I suppose it's possible, but I don't think such shims would be "TYPICAL of factory production".
          • Dale S.
            • November 12, 2007
            • 1224
            Thank you to all. I now have the correct shims. Dale
              • 43242
              Dale-----
              By the way, the original shims were not plated; they were natural steel and rust quickly. The reproduction shims are very close to the originals in configuration but are zinc plated. I much prefer the zinc plated variety. If these were available in stainless steel, I'd prefer those even more.
