The windshield washer on my '65 convertible doesn't work, but my windshield wipers are working fine. I push the small button in the center of the wiper switch, but nothing happens. Should that small button activate the wipers and the water "squirt", or am I missing something? When I push the button, I don't even hear the motor attempt to move the water. I read other posts/threads about this subject, but I don't fully understand the procedure. Is my pump bad, or does it just need to be primed? Should I be continuously pushing the small button as to "pump" the water from the washer jar up to the windshield nozzles? If the pump requires servicing, can it be done without removing the entire wiper motor assembly? I was told that the distributor would have to be removed in order to get the motor assembly out, but I really don't want to mess with that. As always, your guidance is appreciated!
Thank you,
Roger Piper (50141)
Thank you,
Roger Piper (50141)
. Do you guys recommend that I also try tapping on the exposed pump or enclosed pump assembly while my son pushes the washer botton to see if the pump might be stuck and simply requires some "motivation"? My brother is a mechanic and has fixed many things over the years with some persuasive "love tapping" with a hammer
. Is there only one fuse for the wipers and the washer, or are there two fuses (one for each)? Who am I kidding - it can't be that simple... right? Let me know what you think, and I'll give it all a try to see if I can get lucky and avoid a pump rebuild.
. Hopefully one of the "easy" fixes will do the trick! I'll keep you guys posted of what I discover (fingers crossed
. I have electronic ignition with a larger-than-stock distributor cap, so the working area is even tighter. Two of the little hex-head screws are tight against the firewall, and the other two are tight against the distributor & spark plug wires. Adding to the "fun" is the extended reach leaning over the fender (I guess it would help if I was taller
