Re: C2 Windshield Washer Issue
To visualize how the system works, you need a copy of the 1963 Corvette Shop Manual (the WSW motor & pump were essentially the same, so coverage isn't great in the 64 and 65 Supplement books.
The pump is driven by the rotation of the WSW motor. There's drive pin on the bottom of the washer that engages with with a hole in the drive gear of the wiper motor. It's easy for a novice to install the pump onto the motor without aligning these resulting in no washer pump action!
When you push the switch to call for washer fluid, you fire a solenoid in the washer pump that releases the pump's ratchet arm onto the pump's drive prawl. That causes the pump's piston arm to move back and forth to execute the pumping task.
All the descriptive text aside...if you remove the plastic cover from the washer pump and watch what happens when you trigger the washer switch, you'll be able to see the system working (or trying to work)...
! Thanks again to all who have provided their advice and guidance. I had a printed copy of your comments right next to me during the project which helped me through each step of the task. Once the distributor cap was moved out of the way (I removed 4 of the 8 wires and moved it toward the passenger's side), removing & reinstalling the washer pump wasn't too difficult. The main problem with my washer pump was that the gear wasn't turning and engaging the spring (which in turn pumps the bellows). It was somehow stuck, but once I gave it a few turns, it appeared to work correctly. I used the new nozzle rebuild kit that I purchased from Eckler's since I was already working on the pump, but this caused some unnecessary grief. When I reinstalled the pump, I decided to test it before closing up the distributor. It's a good thing that I did since it still didn't work
! What gives?? I was talking out loud using 4-letter words at will. Why does every small project turn into a big job? I had to remove and reinstall the nozzle section two times (with the pump still installed to the wiper motor housing). The access was difficult, but easier than dealing with the whole pump again. It ends up that the replacement nozzle piece was defective as it wouldn't allow the fluid to flow. After replacing it with the original nozzle unit (using new o-rings & bellows), I had washer fluid spraying and I was ready to hit the road with a clean windshield
. I closed up the distributor, put everything back in order, wiped down the air cleaner & fenders, and went for a cruise. I love happy endings; don't you?
