Air Cleaner Stud - NCRS Discussion Boards
Air Cleaner Stud
  • Steven B.
    • June 30, 1982
    • 4000
    Air Cleaner Stud
    What are the differences , if any, between the original and repo 1957 4" stud that mounts in the carb (2X4's) and attaches the air cleaner?
  • Gary C.
    Administrator
    • October 1, 1982
    • 17771
    Re: Air Cleaner Stud
    Steve, original studs had tapered thread on air cleaner end, rolled threads and if I recall correctly were not threaded end-to-end, just on each end. On 56-7 studs (carb, water neck) there was also a indented circle on the end of one of the thread and not always on the visible end. Don't know if this was a manufacturer's mark or a machining process mark. Gary....
    NCRS Texas Chapter
    https://www.ncrstexas.org/
    • Steven B.
      • June 30, 1982
      • 4000
      Thanks Gary!
      Steve
      • Michael K.
        • January 1, 1991
        • 43
        The carb studs also have a "D" stamped into them. These are available as a good repro but the major vendors do not sell the correct ones.
