67 tele turn signal harness routing - NCRS Discussion Boards
  • Thomas R.
    • December 1, 2003
    • 33
    Did a search and came up empty. Trying to find out proper routing for turn signal harness for 67 tele and also where the the escutcheon(on main harness) with clip is suppose to attach
    Thanks in advance.
  • Stephen L.
    • May 31, 1984
    • 3158
    Re: 67 tele turn signal harness routing
    Routing and clip location are shown in your Aim.
    • Gerard F.
      • June 30, 2004
      • 3806
      Thomas,
      I think the routing is the same as on the standard column. Shown on AIM sheet UPC12 B3.
      The signal switch wiring harness goes down the bottom of the steering column through and past the instrument cluster, then goes to the passenger side of the steering column and over the top of it, to the body harness connector.
      The body harness connector clips onto the horizontal portion of a brace above the steering column.
      It is really confusing the way it clips on the brace. The curvature of the connector is opposite curvature of the steering column.
      Jerry Fuccillo
      • Thomas R.
        • December 1, 2003
        • 33
        Thanks Gerard!
