70 Tcs - NCRS Discussion Boards
70 Tcs
  • Joseph M.
    • June 30, 1999
    • 334
    70 Tcs
    Does anyone know what the wire clip looks like and where it is attached for the TCS wire that goes to the TCS switch on a manual trans? Tx in advance.
  • William C.
    • May 31, 1975
    • 6037
    Re: 70 Tcs
    Try UPC 7, sheet B6 of the assembly manual, clip mounts off the top dr side trans to bellhousing bolt.
    Bill Clupper #618
    • Jeremy D.
      • November 1, 1998
      • 323
      Re: 70 Tcs
      ...And to my knowledge, nobody reproduces that little clip. It's like a little spark plug wire boot, a little black round boot on the end of a black wire if I remember. I know I searched wiring harnesses and repro outfits.....never did find one. You can still get the jumper wire that goes from the sending unit to the relay repro, but that's it as far as I know.....
      • William C.
        • May 31, 1975
        • 6037
        Re: 70 Tcs
        Actually it was a molded-on part, never available as an individual item as it was not "assembled" but actually molded over the wire and terminal assembly.
        Bill Clupper #618
        • Joseph M.
          • June 30, 1999
          • 334
          Re: 70 Tcs
          Tx for the information, I'll keep looking.
          • William C.
            • May 31, 1975
            • 6037
            Re: 70 Tcs
            Chevelle, GTO and others used similar parts. I'd try some of the major wiring harness reproduction outfits and see if anyone has tooled up the mold and could supply you with a pigtail you could splice into your existing harness.
            Bill Clupper #618
