Starting up 67 427 engine - NCRS Discussion Boards
  • Donald L.
    • November 1, 1981
    • 141
    I want to run a 427-435 saturday and adjust everything before the body goes back on, I have been told there is a oil additive I must use in the older engins to keep the cam from wiping out, there is somthing missing in todays oil that the EPA had removed, anybody know if this is true?
  • Steven B.
    • June 30, 1982
    • 4010
    Re: Starting up 67 427 engine
    'Probably referring to ZDDP posts. It comes up alot. Check Dukes comments on the posts, very good.
    • John C.
      • May 31, 1993
      • 72
      Donald,
      If you are starting the motor up with a new cam shaft you have to run the motor for 20 mins. at 1800 - 2000 RPMs to break the cam in. If you start the motor up with the new cam and don't put heat into it, you'll knock the lobes.
      John
      PS: GM makes a oil E.O.S. assembly lube, has that zinc stuff in it.
      • Ted K.
        • August 31, 1994
        • 337
        Need oil with zinc in it,I believe oil with cj-4 on the bottle is what you are looking for.
        I am using Shell Rotella oil in all my older Vettes.
        Ted
        • Bill M.
          • April 1, 1977
          • 1386
          Do a search on "88862586" which is the part no. for EOS
