69 center exhaust hanger - NCRS Discussion Boards
  • Jim M.
    • February 23, 2009
    • 233
    I'm in the process of putting in a stock exhaust system and have already taken off the headers and old system. My question is about the "U" shaped center bracket that attaches to the bottom of the transmission. Which way does it face? Should it be the open end of the "U" face toward the rear of the car? Jim
    • 43258
    Re: 69 center exhaust hanger
    Jim-----
    Yes.
    • Tom D.
      • September 30, 1981
      • 2138
      Was this part not used on early 1966 Corvettes? This particular VIN indicates car number 2999.
      https://MichiganNCRS.org
      Michigan Chapter
      Tom Dingman
        • 43258
        Tom-----
        Yes, the same part was used for 1966 Corvettes with 2" exhaust. All 1969 Corvettes, the subject of this thread, used 2" exhaust. A similar part, but of slightly different configuration, was used for 1966 with 2-1/2" exhaust.
        • Tom D.
          • 2138
          Another member recently pointed out that the AIM drawing was changed to add the hanger after the start of 1966 model year production. I find it hard to believe that any mid year Corvettes were made without a center exhaust hanger. Comments?
          Michigan Chapter
          Tom Dingman
            • 43258
            Tom-----
            1963 and possibly early 1964 used a different style clamp set-up. However, most 1964 thru 74 used the "ox bow" style brackets, 65-67 and 69 side exhaust excepted.
              Another member recently pointed out that the AIM drawing was changed to add the hanger after the start of 1966 model year production. Comments?
              Tom -
              That's incorrect - the oxbow hanger (called a "clamp") has been in UPC 8 in the Assembly Manual since 1964, when it was introduced. The only item "added" to the 1966 A.I.M (UPC 8, sheet A2, item #14) after the sheet was issued was a note about reference clearance dimensions.
