71 Charcoal Cannister Part # - NCRS Discussion Boards
  • Jeff M.
    • February 1, 1999
    • 127
    My original is part number 17063011, I found an NOS one that is part # 17056582, other than the part number what is the difference and can it be used without functional problems
  • Edward C.
    • March 1, 1985
    • 125
    Re: 71 Charcoal Cannister Part #
    Was there a service and/or replacement time/mileage on these canisters? Thanks. Ed
      • 43281
      Jeff-----
      GM #17063011 is NOT the originally installed vacuum canister for your car. It's a replacement that occurred after 1983. The original canister for your application was GM #7028129. It was discontinued from SERVICE in August, 1971 and several other supercessive part numbers were used before they got to the 17063011..
      The GM #17056582 is another replacement for your application, so that part will SERVICE your application just fine.
      • Harmon C.
        • August 31, 1994
        • 3228
        The only difference in I see on the charcoal canisters is they added another hose every few years so a later part will need lots of rubber caps to plug the unused holes.
        Lyle
        • Jeffrey S.
          • May 31, 1988
          • 1902
          Joe and Lyle:
          I have a canister with part #7029131. Do you know what this is from? Thanks.
          Jeff
            • 43281
            Originally posted by Jeffrey Salz (13182)
            Joe and Lyle:
            Jeff
            Jeff-----
            You better double check that number. I show GM #7029131 to be a carburetor lever and NOT a charcoal canister.
            • Jeffrey S.
              • May 31, 1988
              • 1902
              Joe:
              Sorry! The number is 7028131. I hit the wrong key. Thanks for you help.
              Jeff
                • 43281
                Joe:
                Jeff
                Jeff-----
                GM #7028131 was originally used for some non-Chevrolet 1971 GM applications. As far as Chevrolet goes, it was used for all 1974 with 8 cylinder engines and some limited use during 1975-77. As far as Corvettes go, it's the canister used in PRODUCTION for all 1974-77 models.
                • Jeffrey S.
                  • May 31, 1988
                  • 1902
                  Joe:
                  As always, thanks for the response.
                  Jeff
                  • Brad M.
                    • July 31, 2005
                    • 262
                    The one on my 71 has the numbers 7030541 and 125 on it. No idea if it is original, but it has been on the car long enough that it had paint overspray from previous repaint which probably occurred 20 or more years ago.
                      • 43281
                      Brad-----
                      If it's a very late 71 I could see where the 7030541 might have been the originally installed canister. Otherwise, it's a replacement that occurred sometime after August, 1971 when the 7028129 was replaced, for SERVICE, by the 7030541.
                      • Brad M.
                        • July 31, 2005
                        • 262
                        Joe,
                        My car is 18294, so around 1st of June, 1971. It does not seem to quite match what you are saying.
                        Any idea what the 125 indicates? I was guessing it could be a date code???
                          • 43281
                          Joe,
                          Brad-----
                          I would say that June, 1971 would be late enough to have received the 7030541. I expect the "125" is a date code but I don't know how to interpret it.
