Correct Plugs For 1970 Lt1 - NCRS Discussion Boards
  • Paul S.
    • June 30, 1982
    • 359
    43n ? Should It Have Green Rings? Does Anyone Have A Set ?
  • Kenneth H.
    • October 27, 2008
    • 500
    Re: Correct Plugs For 1970 Lt1
    Paul,
    Per the owner's manual, the OEM plug was an R-43. The owner's manual also says that for city driving use an R-44. There was a pretty good discussion around mid-April concerning spark plugs for a '70 LT1. It was titled "Spark plug advice for my '70 LT1".
    Concerning the rings, I believe that 4 equal rings were standard on plugs for 1970, but there are a bunch of guys here that know worlds more that I and I'm sure that they will advise.
    • Larry M.
      • January 1, 1992
      • 2702
      Four equal rings is correct. Would not use a 43 heat range due to early fouling. A few guys in the Driveline advertise vintage plugs for sale with the correct four thin/equal green rings. Also available on E-bay.
      Larry
      • Dave S.
        • August 31, 1992
        • 2930
        Paul,
        43N would be a Big Block. The actual period correct AC plug for your 70 LT-1 would be an R-43 with 4 equal rings and ACNITER in green on the shaft. They are very scarce and be ready to compete with the Z-28 folks when you find them. I looked for a long time and finally found a set a few years ago. The date on the box that I have is 1970. 43 heat range is a bit cold for the street so if you find a set you may want to put them on the shelf.
          • 15706
          Unless you're really pounding on it all the time, the AC R45 or equivalent in any other brand is best for normal road driving.
          • Dennis D.
            • March 1, 2000
            • 1071
            Best change I made to my 70 L-46
            • Jeremy D.
              • November 1, 1998
              • 323
              Last I checked, you can't get a plain R44 from ACDelco anymore.....they're either 43's or 45's, which I agree work great.
