Rebuild engine - NCRS Discussion Boards
Rebuild engine
  • Bo B.
    • November 17, 2008
    • 29
    Rebuild engine
    What will it take to rebuild the present 300Hp engine to a 350Hp engine?
    Will it be possible to bring it back to 300Hp if nessesary?
    Just like to have an extra 50Hp
    Bo
  • Steven B.
    • June 30, 1982
    • 4005
    Re: Rebuild engine
    Bo
    Bo, begin with head work. You can get good gains with head work and it will never show from the the outside. There have been alot of threads on head work that will be valuable to you.
    Steve
    • Mike M.
      • September 30, 1999
      • 710
      Re: Rebuild engine
      Why would you want to change it back?
      • Joe T.
        • October 25, 2006
        • 304
        Re: Rebuild engine
        If you mean to THE 350 hp status(as in the original 350 configuration), the valve train is changed from hydraulic to solid; the carb is different;I think the intake manifold is different; the distributor is different...and the list goes on. However, if you just want to get an extra 50 HP, you have a multitude of choices, and 50 hp is, by NO MEANS, the upper limit...Joe
          • 15706
          Re: Rebuild engine
          The L-79 did not have mechanical lifters.
          The secret to horsepower is head flow. If you massage the OE heads, retard the OE cam four degrees, and do nothing else it will make about as much top end power as a Flint-built L-79 with a lot more low end torque, and it will look absolutely original and idle butter smooth at 500 like a 327/300 should.
          • Joe C.
            • August 31, 1999
            • 4598
            Re: Rebuild engine
            Originally posted by Joe Tutela (46448)
            Sorry...I thought he was looking for the LT-1? My error. I didn't see the year in the signature
            I was so angry when I saw your post, yesterday, that I was too agitated to castigate you.
            NO SOUP FOR YOU!
            • Bo B.
              • November 17, 2008
              • 29
              Re: Rebuild engine
              Gentlemen
              Thank you on all advise.
              Where can I get this done in the Houiston area.
              Any suggestions.
              Bo
              • Jean C.
                • June 30, 2003
                • 688
                Re: Rebuild engine
                Bo, you have Email.
                Best regards,
                • Jim S.
                  • March 1, 1986
                  • 1408
                  Re: Rebuild engine
                  Bo
                  Bo,
                  If you are speaking of rebuilding it as it was back in 65 ,the answer is no . The 350 Hp had "at least" ,a different cam and larger head valves, and a different intake, (aluminum). So while you could replace the intake again with the 300 Cast iron one ,the cam and Valve changes would remain .
                  If you just want more horse power then Duke's advice is the way to go .
                  Jim
