1958 wiring - NCRS Discussion Boards
1958 wiring
  • Susan G.
    • May 31, 2005
    • 136
    1958 wiring
    Hi there, I have the wiring diagram and it shows a black and white ground going to the engine compartment but not where it goes. It would take a 1/4" bolt. Second question is the black radio ground the assembly manual shows it going to the valve cover. I don't have a hole there already and am not sure this is correct, can some one confirm that is correct.
  • William C.
    • May 31, 1975
    • 6037
    Re: 1958 wiring
    I believe they both wind up on the bolt that retains the valve cover.
    Bill Clupper #618
    • Steven B.
      • June 30, 1982
      • 4015
      Re: 1958 wiring
      For the black/white the terminal ends have holes in them that the VC bolt passes through, not the spade type.
      • Mike M.
        • May 31, 1974
        • 8408
        Re: 1958 wiring
        i believe the black and white ground goes under the upper rear drivers side valve cover fastner but i think the ground strap goes under the spark plug wire bracket(that also fastens the left vertical ignition shield) at rear most intake manifold bolt on the drivers side. AIM ought to show both locations. mike
        • Susan G.
          • May 31, 2005
          • 136
          Re: 1958 wiring
          Aim shows the black radio ground going to the corner of the valve cover, not a valve cover bolt. Are you guys sure about location?
          Susan
          • William C.
            • May 31, 1975
            • 6037
            Re: 1958 wiring
            About all I can say is I just went out to the barn and looked at my '62. There are two descrete wires (one larger than the other) firmly attached to the top rear valve cover bolt. Everything Works, and looks like it belongs there. Same wiring as a '58 in the heater and engine compartment.
            Bill Clupper #618
            • Dennis C.
              NCRS Past Judging Chairman
              • January 1, 1984
              • 2409
              Re: 1958 wiring
              I believe black/white wire comes throught LH firewall and attaches to upper rear VC bolt.
              On right hand side, 1 black ground from wiper motor base goes to RH upper VC bolt.
              If radio equipped, another black wire also goes to the upper valve cover bolt on RH side.
