1967 wiring - NCRS Discussion Boards
1967 wiring
  • Jeremy H.
    • January 1, 1999
    • 260
    1967 wiring
    What makes the "lights" indicator flash on the cluster when the headlights are on, but the buckets are not up? A have a 67 with all new wiring and new limit switch's, what could be the problem? Everything else works.
    Jeremy Hedges
    #31711
  • Rich P.
    • January 12, 2009
    • 1361
    Re: 1967 wiring
    Jeremy,
    are you saying that the warning light is not flashing?
    You also need a specil bulb (I think a 257 but not positive) otherwise it will only light up when activated and go off when limit switches are activated. And not flash as intended.
    Rich
      Re: 1967 wiring
      Yes, Rich is correct, the lamp used in the '67 headlight warning position on the dash is a 'flasher' lamp (GE #257) which has a special filament to make it blink. Your copy of the owner's manual should have a lamp chart which calls out what lamps are used where in the car...
      Not installing the special blinker bulbs in mid-year cars is a VERY common restoration mistake that judges see all the time.
