C3 Turn Signal Switches - Joe Lucia - NCRS Discussion Boards
  • Jim S.
    • August 31, 2001
    • 730
    Joe,
    Can you supply the turn signal switch part numbers for standard and tilt & telescoping steering columns (1969 through 1982). I will try and sort out which switches did what.
    Jim
    • 43213
    Re: C3 Turn Signal Switches - Joe Lucia
    Originally posted by Jim Shea (36737)
    Joe,
    Jim
    Jim-----
    standard column
    1969-72-----GM #1997949
    1973-76-----GM #1997969
    1977-79-----GM #1997988
    Each of the above superceded the prior part number for SERVICE and the GM #1997988 remains available to this day to SERVICE all 69-79 standard columns.
    tilt/tele column
    1969-76----GM #1997950
    1977-E79----GM #1997983
    L1979-82----GM #1997984
    GM #1997950 was discontinued from SERVICE in September, 1977 and replaced by GM #1893584. The latter part was discontinued without supercession in July, 1999.
    GM #1997983 was discontinued from SERVICE in July, 1994 and replaced by GM #1997988 (yes, the same switch as used for 1977-79 standard column applications).
