I'm having my car painted in it's original color, tuxedo black. The outside rocker panels on a 69 are black with a little chome trim at the top. I'm wondering if I should have the rocker panels repainted as well? If so, are they supposed to be a shiney black like the body of the car or sort of a semi gloss?
69 rocker panels
Re: 69 rocker panels
Jim-----I'm having my car painted in it's original color, tuxedo black. The outside rocker panels on a 69 are black with a little chome trim at the top. I'm wondering if I should have the rocker panels repainted as well? If so, are they supposed to be a shiney black like the body of the car or sort of a semi gloss?
The 68-69 rocker moldings are a 2 piece arrangement. The upper molding is clear anodized aluminum. The top portion of it is bare, clear-anodized aluminum; the lower portion is painted a semi-flat black. The lower molding is a fiberglass panel. It is painted a semi-flat black.
All 1969s, except side exhaust of course, used the same molding regardless of body color of the car.In Appreciation of John Hinckley- Top
Thanks Joe. Sounds like from what you say that I shouldn't have the panels painted tuxedo black like the rest of the car but should either clean them up or have the paint guy use a semi flat or maybe a satin paint on those two pieces.- Top
Hey Jim -
I just restored my rocker panels on my '69 L36. I asked around and found John Deer's Blitz Black to be one of the favorites for properly matching the original flat black on the rocker panels.
I purchased mine on-line from this place;
One can should do the trick.
Good luck!
Rob- Top
Rob-----Hey Jim -
Good luck!
Rob
Yes, John Deere Blitz Black is just about the right sheen level for these rocker panels. In general, and contrary to the opinion of many, I don't think that Blitz Black mimics the gloss level for very many Corvette chassis parts. However, it is about right for these rocker panels.In Appreciation of John Hinckley- Top
