1972 Vehicle Certification Label - NCRS Discussion Boards
  • Bryan M.
    • April 1, 1999
    • 386
    Did the different options on a car change the gross weights on the 1972 blue certification label?
    Thanks.
  • Roy V.
    • April 8, 2008
    • 301
    Re: 1972 Vehicle Certification Label
    my '72 small block without a/c but with p/s,p/b and elec. windows.
    GVWR is 3910
    GAWR front is 1810
    GAWR rear is 2100
    1972 LT-1 Elkhart Green Coupe
    • Bryan M.
      • April 1, 1999
      • 386
      GVWR is 3910
      GAWR front is 1810
      GAWR rear is 2100
      Roy,
      My 1972 LT-1 with a/c, ps, pb, no pw, TT and deluxe interior (if that makes a difference). weighs in @:
      GVWR - 4010
      front - 1890
      rear - 2120
      Wow! 100 lb difference.
      • Roy V.
        • April 8, 2008
        • 301
        Bryan, I also have the tilt/tele option and the deluxe interior as well, so the only difference I can see is the addition of the A/C in your car.
          • 15602
          Yes the options changed the weights shown on the label -- but not all the options made those changes. Body style, engine, transmission and AC all changed the weights. I believe PS, PB, PW did not.
          • Bryan M.
            • April 1, 1999
            • 386
            Roy,
            Do you still have the original front coil spring ID label on your car? If so,
            Do you know the letter code?
            • Bryan M.
              • April 1, 1999
              • 386
              Terry,
              Just trying to add all the pieces together.
              • Roy V.
                • April 8, 2008
                • 301
                Originally posted by Bryan Montford (32138)
                Roy,
                Bryan, while I still have the original coil springs, the ID labels have long departed. This is a quote from the technical manual
                "Original front springs had a green paper tag with black lettering giving a two letter broadcast code and the GM part number in black.Service replacement springs have a yellow plastic tag with the GM part number in black. It is not allways possible to see the spring tags because they are sometimes too far into the frame cover"
                Engine - 350
                Sprung Load under 720, spring part#3931823, spring code HS
                Sprung Load over 720, spring part #3931824, spring code HT
                • Bryan M.
                  • April 1, 1999
                  • 386
                  Engine - 350
                  Roy,
                  I crawled under the car and took a pic of the passenger side front coil spring. From your description they look like originals.
                  • Steven G.
                    • November 17, 2008
                    • 348
                    The GVW was not added until about Jan. 1972, corvettes with a previous build date only displays a VIN# and build date on the blue label, I think this applies to all GM vehicles as well. Steve
                    • Bryan M.
                      • April 1, 1999
                      • 386
                      My car has a April 27 1972 build date.
