67 wiring issue - NCRS Discussion Boards
67 wiring issue
  • Jeremy H.
    • January 1, 1999
    • 260
    67 wiring issue
    I am getting a 67 frame off finished. All new wiring. It is blowing the 20 amp fuse (courtesy, hazards, clock and lighter). Unplugged all of that and started plugging one in at a time until we found it is the door jamb switch's. Everything is fine until you put either jamb switch in, then the fuse blows. Either one does the same thing. Any thoughts? They are original switch's. Haven't tried some repoes I have yet.
    Jeremy Hedges
    #31711
    Re: 67 wiring issue
    Jeremy -
    Do you have the correct courtesy/dome/rear compartment light bulbs (#90 double-contact)?
    • Michael M.
      • February 15, 2007
      • 455
      Re: 67 wiring issue
      To completely isolate the issue, did you plug in the door jamb switches first to see if it blows with no other load on the circuit? If it is definitely the switches then I would try the repo's just for kicks. If it still blows with the new switches then you need to find the short along those wires.
      • Jeremy H.
        • January 1, 1999
        • 260
        Re: 67 wiring issue
        That was it. I had the rear cargo bulb with a single. Thanks
        • Jeremy H.
          • January 1, 1999
          • 260
          Re: 67 wiring issue
          Can any of you guys help me with my ignition problem? I have another post right after I first posted this one.
          JeremyHedges
