62 master cylinder - NCRS Discussion Boards
62 master cylinder
  • Jim H.
    • April 1, 2002
    • 112
    62 master cylinder
    Can someone tell me if this is the correct mc for a 62? It has EIS on the side of it. I am thinking it was a replacement.
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 62 master cylinder
    EIS is an aftermarket supplier. Delco was the original supplier.
    • Jim H.
      • April 1, 2002
      • 112
      Okay, thanks...
      • Richard T.
        • February 1, 1979
        • 858
        Jim,
        The casting number "5456022" is located on the outboard side of the cylinder and the last three numbers(022) are much larger than the rest. Also there is a welch plug pressed into the front of the housing and the part number "5454480" and 320-G are stamped into it. Rich
        • John F.
          • March 23, 2008
          • 2415
          See attached photos of 62 master cylinder. Best I could do tonight.
          • John F.
            • March 23, 2008
            • 2415
            Having trouble with photos. Hope this helps.
