T-10 4th Gear Removal - NCRS Discussion Boards
  • Daniel B.
    • July 31, 1994
    • 5
    Greetings. I have the main shaft assy on the bench with the forward snap ring removed but the syncronizer spline will not slide forward off the shaft. It appears to be contacting the forward groove area where the snap ring rests. Is removal of the syncro and 4th gear toward the forward end of the shaft? Thanks, Dan
  • Timothy B.
    • April 30, 1983
    • 5202
    Re: T-10 4th Gear Removal
    Dan, Someone will correct me if I am wrong but I think the syncro will tap off with a block of wood, make sure you keep it square when tapping. The next gear (Third) will also remove from the front.
    • William C.
      • May 31, 1975
      • 6037
      Occasionally a press is required, I use a samm one from Harbor freight and have never either broken anything nor found a trans that would not disassemble with that pursuasion.
      Bill Clupper #618
      • Daniel B.
        • July 31, 1994
        • 5
        Thanks! I opted for a rubber mallet which was handy and coaxed it apart. Now to buy a real set of snap ring pliers.
        Dan
