Interior Trim Paint - Black '67 - NCRS Discussion Boards
  • Tom D.
    • September 30, 1981
    • 2140
    I am working on a C2 Coupe with black interior. The NOS brown plastic trim around the rear window does not like the "spray dye" sold by Paragon and recommended for use with "Vinyl - Leather - Plastic - Carpet". Perhaps it was the plastic primer that I used, but the second repaint still came out with some very dull and some semi-gloss areas. I'd call it blotchy, if that is a word...
    I'm sanding with 600 and will try Krylon or John Deere Blitz black next. I will test on the back side first.
    Also, on the windshield inside trim, it appears the lower bottom pc. is more dull than the sides and top. I am thinking of not painting that part, because it sure looks original and I don't like glare. It looks as if it never did match...
    Comments?
    https://MichiganNCRS.org
    Michigan Chapter
    Tom Dingman
    Re: Interior Trim Paint - Black '67
    Tom -
    I've had good results with SEM #39143 Trim Black for black interior parts. The bottom windshield garnish molding IS a different gloss than the side and top moldings, for glare reduction - it's pretty much flat.
    • Brian M.
      • February 1, 1997
      • 1840
      I like the SEM also. I would also be sure that the parts to be painted are warm, I also warm the paint in a container of warm water prior to use.
