Front shock bolt question nut striped - NCRS Discussion Boards
  • Wayne P.
    • January 23, 2008
    • 444
    The nut that is welded on the lower a-arm that holds the shock bolt is stripped. One out of two.
    The bolt will not tighten properly. I tried lock tite doesn't work.
    Should I tap the next size up bolt ? Thinking of liquid metal and re tap .
    Thanks in advance
  • William C.
    • May 31, 1975
    • 6037
    Re: Front shock bolt question nut striped
    How about a Helicoil? Should be undectable once the assembly is together.
    Bill Clupper #618
    • Ken A.
      • July 31, 1986
      • 929
      Remove the A-arm, actually just undo the ball joint & remove spring, & weld in a new nut. There is too much load on this bolt for anything else to work. Or, if you want a quick fix, get a longer bolt & stack a nut on top of the old one.
      • Wayne P.
        • January 23, 2008
        • 444
        Thanks I think stacking a nut with a longer bolt will get me through the summer. I will weld a new nut on in the fall. Thought of a Heli coil not sure if I can install it with the a arm on.
