1964 distributor ID band - NCRS Discussion Boards
  • Eugene G.
    • July 31, 1982
    • 62
    I am trying to decipher the aluminum band on a distributor I removed from my 64. The band is red and it reads:
    1111069 DELCO REMY 0 J 13.
    My car is a365hp. It has the 236 vacuum unit attached.
    It looks like this distributor was only used on 64 and 65 Corvettes only.
    Shouldn't the 0 be a 4?
    Thanks for any help
  • William C.
    • May 31, 1975
    • 6037
    Re: 1964 distributor ID band
    Service replacement from 1970 very likely.
    Bill Clupper #618
      • 15640
      Unless it is a mis-stamp or an service replacement.
      Nice to see you on here Gene. I hope you are doing OK.
      • Steven G.
        • November 17, 2008
        • 348
        Gene, I read that 1111069 is a second design distributor and correct for 64 + 65 corvette 365 hp. Steve
        • Wayne M.
          • March 1, 1980
          • 6414
          Gene -- definitely a service job, as Bill says. I ordered a 1111069 [with the 236 vac can] from local Chev dealer in 1980, the tag reads 0_D_23; mine is probably even 1980, as there's a hole for the nylon thrust button opposite the tach drive gear, which first appeared on the cast iron housing sometime in the summer of 1970.
          • Eugene G.
            • July 31, 1982
            • 62
            Thank you all for your input.
