original 55 oil pan photos please - NCRS Discussion Boards
  • Mike M.
    • May 31, 1974
    • 8401
    come on roy, git yer Brownie out and shoot some pics of an original 55 265 oil pan for old mikie. thanks,mike
  • Tom P.
    • April 1, 1980
    • 1815
    Re: original 55 oil pan photos please
    With that question in mind, did the 55 Vette and pass cars share the same pan? As well as 55 trucks?
    • Bill M.
      • April 1, 1977
      • 1386
      OK 55 engine block used no oil filter so both side ends have the same curve
      Roy posted this a while back.
      • Michael L.
        • July 31, 2005
        • 562
        Was the one shot enough or do you need more? My pan is off right now I could get you more if you need them.
        Mike
        • Mike M.
          • May 31, 1974
          • 8401
          how about a side view and the shallow portion under rods 1 thru 4. think there out to be a triangular stamping in the shallow portion. thanks much,mike
          • Loren L.
            • April 30, 1976
            • 4104
            Call Mr. Kerbeck and ask him to have one of his "documentation specialists" take a picture of the pan in "Old EX-122"........
            • Doug F.
              • November 1, 1983
              • 322
              mike here a few 55 pics, hope it helps, cary
              • Mike M.
                • May 31, 1974
                • 8401
                thanks much doug and michael. mike mccagh
                • Karl L.
                  • February 1, 1977
                  • 174
                  QUESTION ABOUT "55" OIL PAN....
                  Did the "55" oil pan come two ways? With or without a baffle.
                  The picture of Roy's pan has a baffle.
                  This picture shows no baffle..
                  In my Chevrolet Parts Book ...Effective Feb. 1st, 1961
                  Listed in.. Gp. #1.426 PAN-PAN UNIT, Oil,with Drain Screw
                  55 ALL,CORVETTE (8cyl.) 18 Holes - w/o baffle #3704925 1 $12.70
                  Roy's pan...same GM number.
                  Assuming an Engineering change for better oil collection by oil sump,
                  would a person be better off going thru the expense to buy and use the baffled pan?
                  Karl.
                  • Mike M.
                    • May 31, 1974
                    • 8401
                    karl: my pan has the baffle .mike
                    • Karl L.
                      • February 1, 1977
                      • 174
                      Mike,
                      What # is your "55"?
                      I have #627
                      The motor is a "57" Turbo-glide according to the numbers.
                      So, I'll have to build one. Want to make sure pieces are correct.
                      Karl.
                      • Roy B.
                        • February 1, 1975
                        • 7044
                        The baffle was a running change but when ? The truck also used the same oil pan that I know of, 55 oil pan is all by it's self . Even now finding a good oil pan can run $300.00 and up like the intake, again 55 only intake nothing els like it. Even the front timing cover is rare, also the oil dip stick tube (fits no other engine) and oil stick is all by it's self (vary rare to find) The JM dont memtion the timing cover or oil stick
                        • Michael L.
                          • July 31, 2005
                          • 562
                          Karl, my car is #175. It was previously a drag car, I bought it from a guy who raced it ( 454 with a Muncie M21...) I converted it back to a 265 and cast iron PG out of a passenger car. My car is a driver, many reproduction parts...
                          Mike
                          • Mike M.
                            • May 31, 1974
                            • 8401
                            Originally posted by Karl Litzner (1264)
                            Mike,
                            I have #627
                            Karl.
                            my ole 55 is vin 1416. hollar if i can help.mike
                            • Roy B.
                              • February 1, 1975
                              • 7044
                              Mike mine is #401 F month
