Information On Alarm Horn For 1972 Corvette - NCRS Discussion Boards
  • Bill E.
    • February 20, 2009
    • 38
    I Like To Know If The Trumpet On The Horn Is Plastic Or Metal.the One I Took Off My Car Was Plastic.the Plastic Horns Look Shorter Than The Metal. My Car Was Built In Oct. 1971 Which One Should I Have. Thanks Bill
  • Don L.
    • August 31, 2005
    • 1005
    Re: Information On Alarm Horn For 1972 Corvette
    Bill, the horn itself is metal, with female threads to accept the black plastic trumpet. Hope this helps!
    Don Lowe
    NCRS #44382
    Carolinas Chapter
    • Bill E.
      • February 20, 2009
      • 38
      Hi Don You Telling Me I Can Unscrew A Metal Trumpet Horn And Replace It With A Plastic Trumpet Horn.is The Plastic Horn Right For My Car (built Oct 1971) Thanks Bill
      • Don L.
        • August 31, 2005
        • 1005
        I've seen numerous alarm horns, but none of the ones I've seen have had metal trumpets. Mine is an August '71 build, and it definitely has a plastic trumpet. Looking forward to others ringing in on this, as it's now a mystery to me.
        Don Lowe
        NCRS #44382
        Carolinas Chapter
        • Bill E.
          • February 20, 2009
          • 38
          Hi Don Go On Ebay Now And Go Under (corvette Horn) You Will Two Metal Trumpet Horns. Bill
          • Mike E.
            • February 28, 1975
            • 5141
            Bill
            I just went on ebay. One describes it as a metal horn--he doesn't make any claim about the trumpet--the other doesn't even know if it's a Corvette horn or not. Did I miss something?
            • Don L.
              • August 31, 2005
              • 1005
              Bill, please share ebay item #(s) so I can be sure that I'm looking @ the same horn(s) as you are. I saw ebay item # 200317155002, and it says "metal", but as Mike points out, that doesn't mean that the whole horn is. The head should be metal, and (I think) the trumpet plastic.
              Does this horn look right for a '72? been a while since I had mine down, but the mounting bracket doesn't seem right, and the trumpet, at least from the angle in the photo, looks longer than I'd expect. Might be worth a "Q" or 2 to the buyer?
              Don Lowe
              NCRS #44382
              Carolinas Chapter
              • Tom L.
                • October 17, 2006
                • 1439
                Can't help today, I'm gonig away for a few days, but I can inspect my early Oct '71 build '72 LS-5 next week if you like.
                  • 15621
                  The original alarm horns on 1968-1972 Corvettes have a plastic screw-in trumpet. I have seen all metal horns with a long straight trumpet -- I believe they serve some function on Buicks or Cadillacs. The service replacement alarm horn has a snail shape, like the regular Corvette horn(s) and produces a different sound than the straight plastic trumpet alarm horn.
                  • Don L.
                    • August 31, 2005
                    • 1005
                    Terry/Bill - the horn I see on ebay looks to be the Caddy/Buick one as you described. Ad says Corvette, however, I think the trumpet looks to be too long and the mounting bracket doesn't look like it would attach to the fender well as a Corvette requires. Buyer beware.
                    Don Lowe
                    NCRS #44382
                    Carolinas Chapter
                    • Gerard Q.
                      • February 1, 2000
                      • 284
                      Alarm horn on my 71
                      • Bill E.
                        • February 20, 2009
                        • 38
                        Hi Guys. Thank You Very Much For The Information. Bill
