C1 Bellhousing Removal - NCRS Discussion Boards
  • Joe P.
    • October 4, 2007
    • 209
    I am about to swap Transmissions for my car, and i also have the correct 1960 bellhousing.
    The car is still in hibernation, and I was wondering if it is possible to remove the bellhousing while the transmission is out without removing the engine?
    Joe
    • 43220
    Re: C1 Bellhousing Removal
    Joe
    Joe-----
    Yes, it's possible.
    • Bruce B.
      • May 31, 1996
      • 2930
      Undo the clutch linkage, remove the starter, take out the bolts around the bellhousing and the bellhousing will come off the engine.
      • Joe P.
        • October 4, 2007
        • 209
        Joe-----
        Yes, it's possible.
        Thanks.. Looking forward to this job..
        • Joe P.
          • October 4, 2007
          • 209
          Bruce, Excellent I will do just that.
          Appreciated.
          Joe
          • John N.
            • February 1, 1975
            • 451
            Joe
            You need to be careful with support of the back of the motor or you may bend the pan. Maybe some of the readers will post their process. I have done this a number of times.
            Regards
            • Dennis A.
              • April 30, 1999
              • 1010
              Joe...
              Don't damage your Oil Pan. John Hinckley designed a wood saddle 91/2'" long piece of 2" x 6", and the sides from 9" long 1" x 6". Mount the sides pieces on top of the base and attach with long wood screws thru the bottom. Cut a clearance notch for the dipstick tube bump on the left side. The saddle will suport the engine on the oil pan rail, leaving the pan claered from damage. I used this with slider bolts to remove both the transmission and bellhousing in good shape. p.s. don't forget to plug the output shaft, unless you like oil all over the place.
              • Joe P.
                • October 4, 2007
                • 209
                Originally posted by Dennis Ambrose (32228)
                Joe...
                Thanks Dennis, I found the post with the cradle drawing and dimensions. I willl be making one shortly.
                Joe
                • Roger W.
                  • January 29, 2008
                  • 567
                  Joe, What is the date on John Hinckly's Post for the cradle drawing? I don't know why I can't find the post.
                  • Joe P.
                    • October 4, 2007
                    • 209
                    Roger, the post was as follows:
                    C1 Transmission Removal September 14th, 2004, 01:41 PM
                    • Roger W.
                      • January 29, 2008
                      • 567
                      Thanks Joe. I guess I didn't go back far enough in the arcives.
