Help identify this engine - NCRS Discussion Boards
  • Troy P.
    • February 1, 1989
    • 1284
    Friend of mine has a 1955 265 V-8 casting 3702534 and stamped OI22785F55F. Can anyone advise what application this might be from? He has both a 2 and 4 barrel manifold and it would be nice to know which is correct for an engine so stamped.
    • 43245
    Re: Help identify this engine
    Troy-----
    If it's a 1955 engine, then it's a 162 HP with 2 barrel carb originally installed in a passenger car or truck with Powerglide transmission.
    • Fenwick B.
      • January 1, 2005
      • 115
      What is the date code on the block?
      • Troy P.
        • February 1, 1989
        • 1284
        Thanks Joe. You're the greatest with numbers.
        As I recall the date codes is "A215". January 21st I believe. Heads are cast within a few days of the block.
