Power steering - NCRS Discussion Boards
Power steering
  • Lincoln S.
    Infrequent User
    • March 29, 2009
    • 14
    Power steering
    Just wondering if anyone has added power steering to a mid year small block car that didn't originally have it. If you did the installation yourself, how difficult was the installation and was it worth the trouble and expense.
  • Bill W.
    • November 1, 1977
    • 402
    Re: Power steering
    Lincoln, I added p/s to my '66 many years ago and yes, it's worth it. I found a complete system from a wrecked '64, replaced the rubber lines, rebuilt the pump, added a new cylinder and have never regreted the move. Very little trouble and I got a good deal on the parts.
    I have heard of owners using a non-Corvette valve body (which has less spring pressure) that have not been happy with the result. See what others on this site have to say. Good luck, Bill
    • Louis T.
      • July 31, 2003
      • 282
      Re: Power steering
      Hi Lincoln,
      Good luck!
      Louis
      • Dale S.
        • November 12, 2007
        • 1224
        Re: Power steering
        Lincoln, I added a 1968 passenger car PS( U-Pull it) to my 67 in the mid 70's. I saved all the original parts relacing every thing but the pitman arm. The passenger system works fine for my use. Email me I have pictures. Dale
        • Lincoln S.
          Infrequent User
          • March 29, 2009
          • 14
          Re: Power steering
          Bill, thanks for you input to my question on adding p/s to a 66. I am assuming that there are aftermarket systems available as well as original equipment. Sounds like you are an advocate for O/E. I appreciate your comments. Thanks again.
          Lincoln
