67 Seat belt underbody cables - NCRS Discussion Boards
  • Henry S.
    • April 30, 2005
    • 816
    I'm restoring the chassis on my 67 and had a couple questions about the cables and attachments for the seat belts to the frame and that area. The judging guide mentions "The steel "birdcage" assembly is visible under the door sill area. This area is typically painted with zinc chromate paint." Does that mean the "birdcage" assemblies are painted zinc chromate or that area of the frame they are mounted to is painted or both? Thanks for any input. Shooter
  • Stephen L.
    • May 31, 1984
    • 3157
    Re: 67 Seat belt underbody cables
    Birdcage is Zinc Chromate paint (Greenish)
    Chassis frame is black
    • Henry S.
      • April 30, 2005
      • 816
      Thanks Stephen. I was pretty sure the manual meant only the birdcage but wanted to be sure. Do you know who makes the right color? Krylon? Shooter
      • Chris E.
        • November 3, 2006
        • 1326
        Is this the anchor point you're referring to? The metal piece that sits around the corner, closest to the camera lens in the this picture? I painted mine black.
        BEFORE
        AFTER
        Chris Enstrom
        2011 Z06, red/red
        • William C.
          • May 31, 1975
          • 6037
          Yes, you can see the correct color in the top of the channel in the first picture. (Greenish)
          Bill Clupper #618
          • Henry S.
            • April 30, 2005
            • 816
            BEFORE
            AFTER
            Chris, Yes that is the area. Like Bill just posted, I believe it is suppose to be painted the greenish color that is visable in your first picture in the channel under the door sill. Thanks for posting. Shooter
            • Henry S.
              • April 30, 2005
              • 816
              Thanks Bill, I'm going to try and pick some of that green up tomorrow. I'm headed for a boat shop someplace. Shooter
