1971 What Color Half Shafts and Drive Shaft - NCRS Discussion Boards
  • Paul C.
    • November 12, 2007
    • 511
    The half shafts and drive shaft on my 71 were painted black. For judging should I just leave them or paint them natural finish. If I should paint them which color and paint should I use? Should either of them have any stenciled numbers?
    Thanks Paul
    • 43247
    Re: 1971 What Color Half Shafts and Drive Shaft
    Thanks Paul
    Paul----
    The driveshaft and half-shafts were not originally painted on any 71. So, for judging purposes, I would remove the paint. This might not restore the original finish, but it will be a lot closer than leaving them painted. Understand that when the paint is removed, they'll rust. That was not the original finish, either.
    • Don L.
      • August 31, 2005
      • 1005
      Driveshaft gets the GM part number. Not sure for auto trans cars, but according to Quanta and original examles I've seen, the '71 and '72 4-speed pt # is 3921675. Stenciled number is in yelllow, 1" characters, and is located approx 1/3 to 1/2 way from the trans to the diff. Others might add whether or not location was specific or random.
      Hope this helps.
      Don Lowe
      NCRS #44382
      Carolinas Chapter
        • 43247
        Hope this helps.
        Don-----
        Yes, GM #3921675 was the part number for the PRODUCTION driveshaft assembly. For 1971-72 Corvettes, the manual transmission and automatic transmission driveshafts were the same.
