1970 Wiper Vacuum Actuator Canister. - NCRS Discussion Boards
  • Ralph B.
    • July 30, 2008
    • 178
    The actuator has (2) mounting studs that have a circular (pan head) shape at the actuator flange end ----What is the correct surface finish of these circular heads? ---- did it get the same gold cadium plating as the rest of the canister and mounting flange or something else?
    Thank you,
    Ralph
    • 43247
    Re: 1970 Wiper Vacuum Actuator Canister.
    Thank you,
    Ralph
    Ralph-----
    My recollection is that the studs were plated just like the rest of the actuator assembly. I believe they were part of the assembly when it was plated.
    • Ralph B.
      • July 30, 2008
      • 178
      Thank you!
      • Kenneth B.
        • August 31, 1984
        • 2091
        Thank you,
        Ralph
        I took mine off plugged the nipple & had the whole thing gold anodized. They worked fine.
        KEN
