1960 license plate lamp assembly - NCRS Discussion Boards
  • Stewart A.
    • April 16, 2008
    • 1035
    My license plate lamp assembly doesn't fit great. Here is a photo they do not fit flush to the end. Have I got a wrong type or is that how they should fit.
  • Mike E.
    • February 28, 1975
    • 5141
    Re: 1960 license plate lamp assembly
    That is not how they "should" fit, it is how they "do" fit. Fit was not perfect out of St. Louis.
    • Roy B.
      • February 1, 1975
      • 7044
      Have you tries to reverse them , ant the nut area movable
      • Mark P.
        • May 13, 2008
        • 941
        Stewy,
        Mine fit like that. In the rear it hung forward like yours and in the front it was a bit forward. One of the welds on the inside was broken so I ground out the other, adjusted it so it fit better and rewelded it. It looks a lot better.
        Mark
        • Stewart A.
          • April 16, 2008
          • 1035
          It's not a correct look, the rear part is perfectly flush. Strange !! I have only seen a handful of 58 -60 cars so it's hard to see the correct fit. Like mine they are all s...t heaps and seem to have the overhang.
          Stewy
