Side Window Install - NCRS Discussion Boards
Side Window Install
  • John M.
    • January 27, 2009
    • 60
    Side Window Install
    The "grip strip" in my car disintegrated and the window cam loose. I have it all apart, but it is not addressed in my factory shop manual. Do you just wrap it around the window and seat the metal piece with a soft mallet? Do you enhance the bond with some weatherstrip adhesive?
    thanks in advance,
    John Myers
  • Mike M.
    • May 31, 1974
    • 8405
    Re: Side Window Install
    you have it correct. be sure to use the channel liner of correct thickness. most glass shops can supply. its black in color, not tan.good luck,mike
    • David D.
      • 77
      When I did mine, I simply sprayed soapy water onto the new channel liner material and used a rubber mallet to seat the glass into the retainer channel.
      Dave
