Motor dyno test; assembly lube question - NCRS Discussion Boards
  • Clem Z.
    • January 1, 2006
    • 9427
    Re: Motor dyno test; assembly lube question
    Can you be more specific? What are the materials?
    Jim
    i do not have the material list here but i will try and dig it up.
      • 15706
      Most oil additives - detergents/dispersants, anti-wear, etc. leave ash, which can form deposits that can increase the incidence of detonation due to loss of combustion chamber volume and/or "hot spots".
      That's why back in the seventies GM recommended "ashless" aircraft oil - basically non-detergent oil in racing engines, but it lacks critical additives such as ZDDP. Aircraft engine valvetrains are very lightly loaded, so they need little or none.
      IMO you should use a well fortified oil like CJ-4 or CI-4. If the engine has proper oil and fuel control, deposits won't be a problem.
      Oil spec sheets like what Chevron has online for Delo list percent ash and CJ-4 is less than CI-4.
      • Jim L.
        • September 30, 1979
        • 1816
        #18
        This much I already knew.
        Are you saying that EOS contains these additives, possibly in abundance?
        Jim
          • 15706
          #19
          I believe it contains a high concentration of ZDDP - not sure about the others.
          • Clem Z.
            • January 1, 2006
            • 9427
            #20
            GM used to include a can in every crate with a new short block and the can had something printed on it about not to be used with regular oil changes
