68 427 not sure which are the right radiator hoses they're different ones for the 427 - NCRS Discussion Boards
  • Brandon T.
    • October 23, 2008
    • 872
    car is a 68 with a l36 427 390hp 4sp...the build date is D07 on the car.
    with that said what are the correct upper and lower radiator hoses off paragons site for it some say 2nd design etc...
    my dad ordered these for it:
    2376UPPER RADIATOR HOSE-UPPER RADIATOR HOSE1$27.00$27.00
    1737LOWER RADIATOR HOSE-LOWER RADIATOR HOSE#3882826 & GM LO1$30.00$30.00
    but he's bad about not researching anything and clicking on the first thing that mentions 68 427....so no clue if he ordered the correct ones or not.
    can anyone give me a little help here?
    as far as lower hose one on their site says: Lower radiator hose w/ reinforcement spring, all w/427 exc. H.D., #3921908 and GM logo
    another says:
    Lower radiator hose with reinforcement spring, #3882826 and GM logo. 1966-67 All w/427. 1968 w/H.D. 427. (this is the one he ordered)
    as far as upper hose goes one says: Upper radiator hose, #3947866, w/427, 2nd design. (this is the one he ordered)
    another says: well NVM I don't think they have more than one style of upper hose for a 427.......so he must have ordered the right upper one for sure.
    thanks!
  • Henry J.
    • November 1, 1999
    • 457
    Re: 68 427 not sure which are the right radiator hoses they're different ones for the
    Brandon:
    I think you are fine with Paragon numbers 2376 and 2182.
    • Henry J.
      • November 1, 1999
      • 457
      Brandon:
      I believe the first design upper radiator hose is GM #3921906
      • Brandon T.
        • October 23, 2008
        • 872
        but which do I need the 1st or the 2nd design on both upper and lower..
        just want to be ready to send them back if they're not what we need.
        btw what is "1968 w/H.D. 427"?
        what is HD 427? I assume HD is heavy duty and maybe that means l88 or something?
        • Henry J.
          • November 1, 1999
          • 457
          Brandon:
          I suspect that the first design is not available. What's out there now in reproduction is the second design.
          Yes, 427 HD usually means L88.
          • Brandon T.
            • October 23, 2008
            • 872
            Originally posted by Henry Jakubiec (33095)
            Brandon:
            well if the one he ordered says this "Lower radiator hose with reinforcement spring, #3882826 and GM logo. 1966-67 All w/427. 1968 w/H.D. 427. "
            that wouldn't be the right one then would it? since it says for 1968 with HD 427...
            and he should have ordered the one that says "Lower radiator hose w/ reinforcement spring, all w/427 exc. H.D., #3921908 and GM logo"
            because to me that says for all 427's EXCEPT HD ..right?
            • Henry J.
              • November 1, 1999
              • 457
              Yes, your understanding is correct.
                • 43247
                Brandon-----
                You need upper radiator hose GM #3921906 (early) or GM #3947866 (late). Neither of these are available from GM. I don't know what the Paragon number is for them. Also, I don't know when the change took place in part numbers. However, I expect it was quite late in the model year.
                The lower hose was GM #3921908. It's no longer available from GM, either.
                • Brandon T.
                  • October 23, 2008
                  • 872
                  Brandon-----
                  so basically he ordered the wrong ones both upper and lower because he ordered these.
                  and ours isn't a HD 427...if HD means l88
                    • 43247
                    Brandon----
                    For the LOWER hose, you need Paragon #2182.
                    For the UPPER hose it looks like Paragon only has available the 2nd design hose. That's their number 2376. I don't know that anyone reproduces the 1st design hose. I think the 2nd design will work, but it may not be "correct".
                    • Brandon T.
                      • October 23, 2008
                      • 872
                      Brandon----
                      Thanks Joe! I'll send the lower one back and order the correc 2182 one.
                      on the upper guess I'll send it back too and just start looking for one that has the correct GM part number in white letters on it for the 1st design..
                      anyone know where this can be found?
                      thanks
