C3 Frame Rust Issues - NCRS Discussion Boards
  • Todd L.
    • March 3, 2009
    • 45
    Would any significant frame rust show up in an NCRS inspection? I am sure it would to a point but here is my reason for asking.
    I am looking at a C3 convertible (long distance and e-mail at this point) to purchase and the owner (who thus far has been very forthcoming and helpful about any questions that I have asked) noted that the frame had only surface rust. The car was was judged at 2nd flight in a show aprox 8 yrs ago. It scored a 491 out of 574 (86%) possible points on the chassis section. So would this help (from afar) in determining if the car has any major rust issues?
    I just joined the NCRS and have ordered my judging guide but I want to move faster than the mail. Any help is appreciated!
  • Randy W.
    • October 23, 2007
    • 24
    Re: C3 Frame Rust Issues
    The answer is: it depends. I wouldn't give too much weight to the 8 yr old judging. Also, they would never have any indication of the condition of the birdcage which is the bigger deal. Get a NCRS or Forum member to look at it if you are concerned.
    Rand
    • Tom H.
      • November 30, 1993
      • 3440
      You might ask to see the actual judging sheets to see if any notations were made regarding rust.
      As another member posted, if you have doubt, have it inspected by a third party.
      Tom
      Tom Hendricks
      Proud Member NCRS #23758
      NCM Founding Member # 1143
        • November 30, 1989
        • 11608
        I doubt that the comments would have too much benefit.
        He needs to send you pictures, lots of pictures.
        See the link in my sig below to my 72. Now go look at my frame pics.
        Surface rust and nothing more. However, it's nice to have the chance to look at them and see "how much" rust there is.
        Patrick
        • Tom H.
          • November 30, 1993
          • 3440
          The ideal situation would be to have the owner put the car on a hoist and photograph key areas of the frame for you. You'll be ableto tell in a hurry with just a few pictures if the car is of the quality you expect.
          Tom Hendricks
          • Lawrence M.
            • January 31, 1995
            • 404
            Todd, back in '01 i had my '69 for sale down at Bloomington. A 1967 small block coupe was in the sale corral near me and I struck up a conversation with the owner. The car had a top flight award displayed which I think was from the chapter level. The owner told me the car was very original, but did have some frame rust. On the drivers side near the rear kickup the side of the frame had a hole rusted thru. a good 1to 1 1/2 inch size. So I would yes a top flight car can show up with rust on the frame. I saw the hole with just a quick look underneath. This would probably be noted on the judging sheets under condition. An original car can loose a lot of condition points and still top flight. Good luck on your search.
            Larry
            Larry
            2002 Z51 Convertible
            1969 L46 Convertible
            • Todd L.
              • March 3, 2009
              • 45
              I went and looked at the vette this past weekend and here are a few pics. I know it is missing a few of the major pieces that make it an LT-1 but I believe it to be a real one based on some of the other items such as #'s(CTU), tach, amplifier still in place, etc. Do you think this amount of rust on the windshield would be an issue? I did not see anything other than surface rust on the frame as it looked solid. I did not get to look behind the kick panels (my bad). I need to remind myself that I am looking at an almost 40 yr old car. I want one I can enjoy but also have a good base for a future restoration if desired. Comments?
              Thanks to all who gave me a good hit list of items to look for during the inspection. Todd
                • 15573
                Frame doesn't look too bad in photo #4, but photo #2 shows what appears to be undercoat on the frame and fuel line (good it is single line) that shouldn't be there. Skeptic that I am, it makes me wonder what it might be hiding. It may just be the car was undercoated at the dealer, but photo #4 is devoid of any undercoat.
                That amount of windshield rust, if it were surface rust, wouldn't scare me -- but those who have fought that battle ought to be heard from.
                Did you collect the numbers and dates from the major components -- engine, carburetor, distributor, and alternator? Those can be expensive if your goal is NCRS awards.
                • Jim T.
                  • February 28, 1993
                  • 5351
                  Todd your first picture of the rust on the inside of the withdshield frame tells me that there is a rusting issure on the top windshield frame.
                  The only way to get an idea of how bad it is to remove the upper stainless steel windshield trim.
                  Two things to find. Rust is advanced enough that the reasonable solution is to replace the upper windshield frame or it has some rust holes, but overall it can be repaired with welded patches.
                  If this is the only place you find, it can be repaired. The upper windshield frame is the easiest and less invasive than other areas.
                  • Todd L.
                    • March 3, 2009
                    • 45
                    All, I think I figured out to get more pics out here. Hope this link works. I did not get any numbers from the Alternator, etc.
                    Thanks, Todd
                    Store your photos and videos online with secure storage from Photobucket. Available on iOS, Android and desktop. Securely backup your memories and sign up today!
