7029207 Q-Jet Question - NCRS Discussion Boards
  • Anthony P.
    • March 31, 2005
    • 42
    Hi all I have (2) questions
    1. I need to know if anyone has any pictures of an ORIGINAL 7029207 DA Q-Jet (1969 4spd 350 350hp)that they could email me?? (anthonypax@optonline.net) I am trying to tell a real carb from a service replacement re-stamp
    2. Does the date for the carb have to be before the engine built day or the car assembly date??
    Thank you for your help
    Anthony
    • 15575
    Re: 7029207 Q-Jet Question
    Caburetor was installed at St. Louis (See AIM for part number or chart), so the date of the carburetor is based on vehicle assembly date.
    • Anthony P.
      • March 31, 2005
      • 42
      Thaks for the info Terry. Now I need to find out the differences between a re stamp and an original carb
      • Jack H.
        • March 31, 1990
        • 9906
        If the 'restamp' has been professionally done, you may not be able to detect any differences...
        • Anthony P.
          • March 31, 2005
          • 42
          I thought that there was a difference between a service replacement carb (re stamped) and the original carbs.
          • Anthony S.
            • April 3, 2008
            • 183
            Anthony,
            By re-stamp I assume you are referring to a factory service carb, not an attemp fake a carb stamping.
            I have what I'm pretty sure is a 7029207 service replacement carb. It is stamped: 7029207 DA
            0454
            I believe that the build date of this carb is the 45th day (Feb. 14) of 1974, which would make it a service replacement carb.
            I'm not too up on the history of this carb, but I think that it was produced for a while after 1969 and was used as a service replacement as opposed to rebuilding the original carbs.
            After all, these were just used cars at one time, & it was cheaper & easier to replace parts than rebuild them.
            I don't have any pics of the numbers, I'll try to post some by the end of the week.
            Anthony
            • Anthony P.
              • March 31, 2005
              • 42
              Anthony,
              I was told that there is a physical difference between an original & replacement carb. Some people re stamp replacement carbs with a 1969 date and try to pass them off as originals.
              I have a replacement carb now, but I want to know what to look for in an original carb.
              Thanks Anthony
