C3 Heater Hose Debate? - NCRS Discussion Boards
    • 15613
    Re: C3 Heater Hose Debate?
    Yes, that's what I said - because you told me years ago.
    Patrick
    I just thought it was worth repeating at this time. I also wanted to point out grooves as opposed to raised ribs..
    FWIW: I was looking at the one hose that failed on my 1970 -- the one from the intake to the heater core. It has the letter U in white on it about every 4.5 to 6-inches along its length.
    • Jeffrey S.
      • May 31, 1988
      • 1890
      Dennis:
      On my '69 that "capped off nipple" is the vacuum line for the AIR pump. Is the Carb the correct number for your car?
      Jeff
      • Jeffrey S.
        • May 31, 1988
        • 1890
        #18
        Dennis:
        I think I read your post incorrectly and I apologize. The carb is not on your car but from your research. The capped pipe is still for the AIR pump.
        Jeff
        • Dennis D.
          • March 1, 2000
          • 1071
          #19
          Originally posted by Jeffrey Salz (13182)
          Dennis:
          Jeff
          Jeffrey... I was told this is a very original car. I do not believe a 70 L-46 has the AIR system. Mine does not. Got me to thinking about it being a calif only for 70 L-46 which uses a 7040205 crb and not the '207. Maybe someone will chime in. Thanks
