Brake light on Right side of 64 - NCRS Discussion Boards
  • Daniel W.
    • April 30, 1991
    • 8
    My brake light and blinker on the right side dosen't work. Tail light is fine. I've checked bulbs and grounds. Since right side works, that eliminates the brake switch, could it be turn signal switch? Left side turnsignal works in rear but not in front.
    Help
    Dan
    • 6950
    Re: Brake light on Right side of 64
    Dan, Do You Have A Test Lamp? Have You Pull The Bulb And Checked For Power To The Rear Socket Either With The Turn Signal On Or Brake Lamp Depressed.
    • Daniel W.
      • April 30, 1991
      • 8
      I have checked with a test lead on the right side with the pig tail unplugged and I have no power to right rear side for brake or turn signal
        • 6950
        Dan. Next Step Is To Check For Power At Directional Switch Under Steering Column-i Dont Have A Wiring Dia. In Front Of Me But I Think The Direction Wire Colors Are Green And Yellow One The Left The Other Is Right, Turn Directional On And Look For Power At One Of Those Wires,if You Have Power , Start Tracing That Wire To The Rear For An Open, If Not, Its The Column Switch.
        • Daniel W.
          • April 30, 1991
          • 8
          That was it, pulled the connector down to check and there was a wire that was pulled out of connector, Plugged it back in and everything is now fine. Thank you much Ed,
          Aloha and Mahalo from Maui.
          Dan
          • Edward S.
            • December 1, 1986
            • 514
            Dan,
            A few of us from here on the east coast have a feeling that was not the cause of your problem, we would like to come out and look at it. We would not take up much room.
            • Daniel W.
              • April 30, 1991
              • 8
              How about if I just think of you all kindly while I'm crusing tonite in 75 degree weather with the top down along the beach road.
              Mahalo
              • Francis F.
                • April 1, 1978
                • 420
                Mahalo
                Daniel,
                Sounds serious..might have future problems,
                who is your family electrician?? What? you
                don't have one. Whell not to worry,I am a
                retired one,just send plane ticket...
                Francis,
