Fan Clutch Stamp... - NCRS Discussion Boards
Fan Clutch Stamp...
  • Irby G.
    • November 1, 2001
    • 267
    Fan Clutch Stamp...
    Is this something that is really needed??? Is this judged??
    Last Question...Was this originally on my fan clutch on my '63?
    Thanks guys.
  • Alan D.
    • January 1, 2005
    • 2046
    Re: Fan Clutch Stamp...
    Do a search of oliva fan clutch stamp
    I do see the mention of a black stamp in the JG, so that may be what it is.
    I did get hit for a point for not having the "CJ"; need to look into this but its low on the list right now.
    • Wayne M.
      • March 1, 1980
      • 6414
      Thanks guys.
      Hi Irby -- if '63/4 is like '65, yes, this is needed and judged -- mentioned in the TIM&JG for the flat bi-metallic element (Schweitzer ? design).
      Note 'Canada' on the patent info. This is a CJ code small block clutch (barely visible etching at top edge). THIS SIDE UP is original -- most have worn away 45 years later.
      • Irby G.
        • November 1, 2001
        • 267
        Wow, excellent picture Wayne. Is CJ an ink stamp?
        • Stephen L.
          • May 31, 1984
          • 3162
          If Wayne's photo is of an original stamp then the stamp for sale on EBay is incorrect.
          Wayne's stamp is 3 lines high while the stamp for sale is 4 lines high and the spacing between "This Side Up" is wrong.
          Maybe there were 2 stamps at Schweitzer.....
          Details... details... details
          • Irby G.
            • November 1, 2001
            • 267
            You're right Stephen. Also, as Alan suggested, i searched the forum for Oliva Stamping and it appears that '63's are not suppose to have the CJ stamp. One less thing to worry about.
            • Wayne M.
              • March 1, 1980
              • 6414
              Irby -- I think the CJ is supposed to be an ink stamp, but it seems etched on this one. This clutch was completely caked in black grime (which is probably why the THIS SIDE UP survived.
              • Henry S.
                • April 30, 2005
                • 816
                If you have the Restorer CD and do a fan clutch search you will find an article by Fred Oliva titled "63-67 Small Block Fan Clutches". It says "The thermostatic bar on this part contains three or four rows of the words "THIS SIDE UP" stamped in black ink. I could not find which Restorer it was in but maybe someone will know how to find out and post.
                If that is the case the one on Ebay would be correct.
                Shooter
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  Originally posted by Henry Shoot (43807)
                  ....article by Fred Oliva titled "63-67 Small Block Fan Clutches". It says "The thermostatic bar on this part contains three or four rows of the words "THIS SIDE UP" stamped in black ink. I could not find which Restorer it was in ...
                  Henry -- coukdn't find Olivia's article, but I did find another, by Henry Molatch, in RESTORER Vol 17 # 3, Winter 1991. He shows pics of both the bi-metalic coil and the strip types of clutches.
                  His bi-metalic strip type appears exactly as in the pic I show above. Three lines; the same letters line up (ie: the middle row, the 'T' in the word THIS is direct, in vertical line, with the 'D' in SIDE of the row above and below, etc.
                  I'm willing to accept there may have been more than one stamp.
                  • Alan D.
                    • January 1, 2005
                    • 2046
                    Fred Oliva's article is Winter 94 Vol 20 #3.
                    • Jeff A.
                      • January 1, 2000
                      • 312
                      Hey - that is my auction.
                      I used an original clutch to make the art for that stamp.
                      Also - I have quite a few original examples still in my collection.
                      More then one must have been used.
                      My Cars
                      • Irby G.
                        • November 1, 2001
                        • 267
                        Jeff,
                        Was year was your original fan from. I wonder if they used the three line from early years and the four lines for the later years or vise-versa. Maybe had both stamps for all the years??? Curious.
                        Aloha, Irby
                        • Jeff A.
                          • January 1, 2000
                          • 312
                          Will have to have a look
                          I knew you were going to ask - got a lot going on right now
                          My Cars
