Engine Storage with ATF - NCRS Discussion Boards
  • Bruce B.
    • May 31, 1996
    • 2930
    #31
    Re: Engine Storage with ATF
    A different approach to engine storage. This is targeted at airplane owners, but should do the same in a car I assume.
    Any opinions??
    TEMPEST AA1000 ENGINE PRESERVATION SYSTEM
    Reciprocating aircraft engines have a propensity to accumulate moisture, especially during times when the aircraft is idle and not being utilized. The accumulated condensation causes oxidation within the engine resulting in accelerated wear and abnormally high iron count on oil analysis reports. The Tempest (patent pending) AA1000 EPS replaces the moist air in the engine with dry air thereby displacing the condensation.
    The EPS simply attaches to the oil filler neck with the appropriate adapter (included) and plugs in to standard AC power. The unit should run continuously. When the blue desiccant material turns pink it may be reconstituted through a simple baking process. Please click here to visit the Tempest AA1000 Engine Preservation System webpage.
    Features:
    • Low cost
    • 90 day warranty with an optional extended
    Description Part No. Price Buy AA1000 TEMPEST ENGINE PRESERVATION SYSTEM 08-07062 $167.95 Aircraft Spruce WEST
    225 Airport Circle
    Corona, CA 92880
    Tel: 951-372-9555
    Fax: 951-372-0555 Aircraft Spruce EAST
    452 Dividend Drive
    Peachtree City, GA 30269
    Tel: 770-487-2310
    Fax: 770-487-2308 Aircraft Spruce CANADA
    150 Aviation Ave.,
    Brantford Municipal Airport
    Brantford, ON N3T 5L7
    Tel: 519-759-5017
    Fax: 519-759-8964
    • Steven B.
      • June 30, 1982
      • 4009
      #32
      Check the link below for the consent decree with the FTC on Z-Max, which they continue to violate; another prosecution is pending right now (Carroll Shelby's 401(k) must have tanked again).
      http://www.ftc.gov/opa/2001/02/zmax1.shtm
      At first before seeing the commercials I thought it must be STP like, then on Two Guys Garage they did a demo of it penetrating the metal--likely very porous--and I thought "so what, oils do penetrate." I wondered what happened to the Dura Lube and Slick 50 commercials. Looks like the Govt. has a lot of catch up to do, just like with patents.
      • Michael W.
        • April 1, 1997
        • 4290
        #33
        Any opinions??
        Not to be rude, but I think we've lost the plot.
        The goal is to put the entire car in low humidity storage. It doesn't do much good having a pristine engine if the frame is rotted.
        I could buy a lifetimes' worth of room dehumidifiers for the cost of that unit and it would help preserve everything in the room- other toys, tools, furniture, etc.etc
        If you're stuck with a pole barn on the wrong side of a swamp, think about a car bag with dehumidifier packs.
          • 11692
          #34
          Originally posted by Michael Ward (29001)
          There's some guy in Michigan named Hinckley (but not the one that shot your sheriff) who follows the same hurry up and do nothing winter storage regimen that I do. He has no problems, so what are you other guys doing to poor cars?
          Yeah, but he has a temperature controlled garage that is larger than the homes many of us live in, so....
