Break-in Additive - Redline vs EOS - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 951
    Can anyone recommend Readline's Break-in Additive over the EOS additive ?
    This is a for a 283 with hydraulic lifters (245 HP).
    Re: Break-in Additive - Redline vs EOS
    Mark -
    EOS will work just fine for break-in, especially with a stock valvetrain.
    • Joe R.
      • July 31, 1976
      • 4552
      Mark,
      I'll ditto what John says about EOS. I've assembled dozens of motors and used EOS on every one. No failures yet! Also, generously used moly on the camshaft and lifters.
      Redline is a great company with many good products. I'll wait for some testimonials and analysis by some people who understand those products from the chemical compositioin.
      EOS works. Tried and proven.
      JR
      • Steven B.
        • June 30, 1982
        • 4016
        'Done 3 with EOS with no problems.
        • Rick S.
          • January 1, 2003
          • 1203
          Well, I will jump in and add to the list of satisfied customers for EOS on my 67 L-79.
          Rick
          • Jeff A.
            • November 1, 2005
            • 199
            The efficacy of the original EOS is pretty well proven. Are the above EOS testimonials referring to the old formulation? Does this also apply to the new, reduced zinc/phosphate formulation (designed not to foul the catalytic converters in newer cars)?
            Jeff
            • Joe R.
              • May 31, 2006
              • 1822
              The new part number EOS is supposedly the same formulation as the old part number.
              • Joe R.
                • May 31, 2006
                • 1822
                Mark,
                Here's some additional info.
                In the following thread, we have it on good authority that GM says it's the same formulation.
                https://www.forums.ncrs.org/showthre...62586&uid=3748
                Here's the thread about EOS available again.
                https://www.forums.ncrs.org/showthre...62586&uid=1507
                Joe
