Tach Drive Lubricant - NCRS Discussion Boards
  • Mark P.
    • May 13, 2008
    • 951
    What kind of grease should I use to lube up a generator tach drive ?
    Director Region V
    • August 31, 1994
    • 1463
    Re: Tach Drive Lubricant
    Hi Mark
    The auto supply stores have a speedometer cable lube.
    It is a fine oil base graphite material.
    HaND
      Mark -
      If you're talking about the internal gearing in the tach drive gearbox on the back of the generator, I've always used white Lubriplate "A" on my 57's, never had a problem.
      • Mark P.
        • May 13, 2008
        • 951
        John - Yes, I am talking about the tach drive gearbox.
        Thanks for your response.
