63-67 Power Window Switch - NCRS Discussion Boards
  • Ridge K.
    • May 31, 2006
    • 1018
    Re: 63-67 Power Window Switch
    I'd like to know what kinda wimp would order a new C-2 SHP with power windows! Here you got a performance engine with posi and a 4-speed, and you can't even open/close your own windows!? Surely you can manage your driver's side window, and as for the passenger side, that's what the chick was for. Let her earn her ride and roll it up herself if her hair is blowin in the wind! And, if she does roll it up when the top is down, well, you just drop her off on the side of the road somewhere and find a new chick!
    Stu Fox
    Stu, I heard you mention that you've done a little drag racing. During the 1960s, when Chevy Super Stock drag racers like Bill Jenkins were pushing assembly line steel bodied cars into the (first 10 second), and then 9 second pass range, NHRA realized that more stringent safety rules must be put into the rule book, and enforced. I was drag racing a big block Chevelle Super Sport in 1969/70.
    I addition to roll cages being mandated for cars capable of 11 second passes, a rule was instituted that side windows must be rolled up during racing passes. The reason you notice that in the mid to late 1960s, NHRA car class numbers had to be applied with decals on glass side windows, was so tower employees could visible see if the side windows were rolled up, right before the christmas tree lights were activated. If the side windows weren't rolled up, the staging lights were turned off, until the side windows went up.
    While tracking the previous owners of my "67 big block Corvette down, I have been told that the reason my car was ordered with power windows, and very few other options, was so the first owner could easily get the windows up, while drag racing on weekends. The rear wheel wells on my Corvette's body, still show the scars of "too wide" slicks rubbing the fender well openings, while the car launched off the starting line.
    That's the reason a few guys ordered power windows, on 4 speed, posi rear end beasts. They weren't necessarily "wimps", in all cases.
    Take care, Ridge.
    • Kenneth S.
      • July 31, 1981
      • 302
      Michael
      Ken
      • Michael H.
        • January 29, 2008
        • 7477
        #18
        Originally posted by Kenneth Schurr (4760)
        Michael
        Ken
        Thanks Ken. I'm now beginning to think it's only the headlamp motor switch that had a different length. Seems like all the input on the P/W switch proves that I'm wrong. Sure isn't the 1st time I've been wrong.
        • Bob J.
          • December 1, 1977
          • 714
          #19
          MH, you've had it right from the beginning. The short lever 63-64 switch is on the left and the later longer lever one is pictured on the right.Bob
          • Michael H.
            • January 29, 2008
            • 7477
            #20
            AH... Thank You !! So, I wasn't dreaming after all. I was beginning to think I was "loosin it". I knew there was a difference in the length on the power window switch toggle. (gizmo)
            Now, about that headlamp motor switch??
            • Wayne M.
              • March 1, 1980
              • 6414
              #21
              ..Now, about that headlamp motor switch??
              Michael -- just happen to have my dash out (still ). Here's a couple of views of my late '65 switch. Checked it with my early '65 (in place in dash) and the toggle projection feels the same. Believe they are the originals.
              • Michael H.
                • January 29, 2008
                • 7477
                #22
                Thanks Wayne. Is the top surface of the toggle about .100" above the flat surface on the sides of it?
                I just looked at the switch in my 66 and it looks about the same.
                • Wayne M.
                  • March 1, 1980
                  • 6414
                  #23
                  ....Is the top surface of the toggle about .100" above the flat surface on the sides of it? ....
                  Yeah -- that's about it. I even tried a stem caliper but was giving me readings of 0.04-0.05" -- too difficult a round edge to measure. But visually, it looks to be a shade less than 1/8".
                  • Michael H.
                    • January 29, 2008
                    • 7477
                    #24
                    That's about what I have on mine. I think it's original.
                    Ok, here we go again. I think the gizmo is longer on replacement headlamp motor switches.
                    By the way, Jack Humphrey sent a note and said that the gizmo is called a toggle. Sounds right.
                    • Mike M.
                      Director Region V
                      • August 31, 1994
                      • 1463
                      #25
                      Yes, Michael. Correct on all counts.
                      HaND
                      • Gerald C.
                        • June 30, 1987
                        • 1283
                        #26
                        Hello,
                        I'm looking to make sure the contacts inside my PW switch are good. Is there a way to take this switch apart (like the headlight switch) so that I can accomplish that task. My tabs along the PW switch are toast so I's like to take it apart...Thoughts?
                        • Jack M.
                          • March 1, 1991
                          • 1154
                          #27
                          I believe this should be similar:
