I have a question on 63-67 console mounted power window control switches. More specifically, the little chrome gizmo that you push with your finger to raise/lower the window. (for lack of a tech term for it)
Original assy line installed switches used one length for the gizmo and later service replacements used a different length.
Unfortunately, I can't remember if originals were tall and replacements short or if it was the other way around.
I think the top edge of the short gizmo was about the same level/height as the bezel around the switch but the tall gizmos was about 1/8" higher?
The part number probably changed in the early 70's ??
The same question for the headlamp motor switch for 63-67.
