Best/Safest Way to Mount 67 Trim Rings and Centers - NCRS Discussion Boards
  • Kirk M.
    • June 30, 2006
    • 1036
    I am going to have my tires mounted first, but after that I need to mount my 67 four clip trim rings and centers. What is the best way to do this without damaging the rings and centers. I just had the trim rings restored and don't want to damage them. Thanks.
    Kirk
  • Rick S.
    • January 1, 2003
    • 1203
    Re: Best/Safest Way to Mount 67 Trim Rings and Centers
    For the center caps, I use my hands. For the trim rings, I use a terry cloth towel and a rubber mallet and hit it at each clip.
    Rick
    • Bill I.
      • January 29, 2008
      • 554
      Kirk, that's the way. TIP put a towel on the floor in case one pops off. Bill.
      • Tom L.
        • October 17, 2006
        • 1439
        Ok, lets lok at it from the other end. What is the best way to remove the center caps without damaging the stainless trim or the freshly painted wheel?
        • Gene M.
          • April 1, 1985
          • 4233
          Lynn
          pull the centers off with your fingers.
          a screw driver wrapped in paper towel, pry in center of each trim ring clip
          • Ridge K.
            • May 31, 2006
            • 1018
            I'm coming up on my 40th anniversery of owning rally wheel equipped Chevrolets.
            I agree 100%, if one CAN,...pull the center cap off with fingers, that's the best approach. I have found a few that simply won't play along.
            Here is a photo of the best tool I've personally found to remove both center caps, and trim rings. It's made by Ken Tool, and usually found for sale in either collector car parts catalogs, and some large auto parts stores.
            I use masking tape on tool edges, on freshly painted rally wheels, when removing center caps.
            This tool is carried in my trunk/storage bins, and is a must for possible flat tires. It's rather inexpensive.
            I highly recommend this tool. Ridge
            • Steve D.
              Infrequent User
              • May 31, 1988
              • 8
              I have also used that tool Ridge, great recommendation.
              62 Blk/Red Fuelie
              67 Elkhart Blue/Blk 427/400 A/C Auto (1 of 16)
              67 Ermine White/Red Coupe 427/390 A/C Auto(1 of 229)
              69 Daytona Yellow/Blk Lthr Coupe 427/400 A/C 4spd
              91 ZR-1 Blk/Blk
              2004 Lemans Blue/Tan Convertible
              2008 Crystal Red Coupe 436HP,Auto - 2008 Special Edition 427 ZO6 #124 of 427
