Generator Arm Trivia C1 - NCRS Discussion Boards
  • Roy B.
    • February 1, 1975
    • 7044
    I've talked in the past how numbers don't concern me when buying parts. This is a one example of a part having the same part# but each being different in design . The top pic. Is 55 to early 58 arm where the generator is mounted on the left side , bottom is the generator arm used on the right side. Notice they have the same part# in bossed in them . I see the second design used many times on restored 55 to 57 Corvettes thinking it's correct by the numbers..
    You see I do like other's then just a 55 Corvette
    Re: Generator Arm Trivia C1
    Roy -
    Don't know about '55, but '56-'57 used P/N 3704884 brace.
    • Ian G.
      • September 3, 2007
      • 1114
      Should the brace for my 59 have a stamped part number as well? What number should it be for a 59?
      • Roy B.
        • February 1, 1975
        • 7044
        Roy -
        Does it look like which arm?
          It's similar to the red one above, but I don't have one lying around - photo below shows the top end if you look closely (I don't have the car any more). When they're painted wrong (orange) on a '57 they show up better.
            I knew I had one somewhere - here's one on the '57 fuelie chassis at Kissimmee; shows the correct shape (appears to be slightly less bend than the ones in your photos), but, as usual, painted wrong.
            • Roy B.
              • February 1, 1975
              • 7044
              I've seen the correct arm's having no number and others having a number , for figure #364
              • Roy B.
                • February 1, 1975
                • 7044
                John, like I mention both pic's you show is the the arm I show un-painted which was used for 55 to early 58 ONLY ,the generator that IS on the left side.The red arm is 58 up. You agree?
                • Stewart A.
                  • April 16, 2008
                  • 1035
                  My early 1960 has no numbers on the arm ?
                  • Roy B.
                    • February 1, 1975
                    • 7044
                    That's not unusual some do some don't
                    • Roy B.
                      • February 1, 1975
                      • 7044
                      Same as the red arm.
                      • Ian G.
                        • September 3, 2007
                        • 1114
                        I'll leave my arm as-is then. though I think its probably a repop.
                        • Roy B.
                          • February 1, 1975
                          • 7044
                          Do they judge for the number/ I dont think so!
                          • Ian G.
                            • September 3, 2007
                            • 1114
                            I just want it to be correct as possible... I'm also lookign ahead, because I probably won't be done restoring this thign for 3-5 years and maybe they'll redo the JG for 58-60 by then. What with all these TDB postings telling people what's correct, I'm sure it will be in there :P
                            Gosh, thanks a lot Roy!
                            • Roy B.
                              • February 1, 1975
                              • 7044
                              It's always the goal to improve the JM , I think many posting here by many members help those that come to this sight , weather it reaches the people that write the JM I don't know. That's what's so great about this forum being able to post pic's ,but remember what I or others post is their opinion and may not be the consensus of all members .
                              So take what I post as a grain of salt
