1970 Strut Rod Restoration Revisited - NCRS Discussion Boards
  • Stephen B.
    • April 1, 1988
    • 876
    The last pictures I posted were after I had utilized gun bluing. The strut rods were a bit more bronze than blue. Now I've dabbed blue layout fluid over the glue bluing. I'd like some opinions of how the look. Keep in mind, I had increase the amount of blue by applying more layout fluid.
  • Gary B.
    • February 1, 1997
    • 7024
    Steve,
    Can you show an image that shows the entire strut rod? Up close, the surface finish looks pretty original looking to me, but it would nice to see the entire shaft in good lighting. Exactly what bluing did you use and where can one purchase it?
    Gary
    • Stephen B.
      • April 1, 1988
      • 876
      Re: 1970 Strut Rod Restoration Revisited
      Here's a picture of the complete strut rods. Notice the blotchy bluing. I started with gun bluing. They turned out more bronze than blue. Next I dabbed blue layout fluid over the gun bluing. I tend to think that the strut rods need a little more layout fluid dabbing.
      • Gary B.
        • February 1, 1997
        • 7024
        Stephen,
        Your technique looks very good to me. I judge mid-year chassis and based on the photos, I don't see grounds for any deducts during judging.
        I'd like to try out your technique. Can you provide specific brand names for the gun bluing and the layout fluid?
        Gary
        • Stephen B.
          • April 1, 1988
          • 876
          Here's pictures of the products. I purchased the layout fluid on eBay for around $12. The gun bluing kit came from Gander Mountain for around $15. I dabbed more layout fluid on the strut rods and shall post pictures in a couple of days.
          • Gary B.
            • February 1, 1997
            • 7024
            Stephen,
            Thanks for the product into. I'm looking forward to seeing your final photos.
            Gary
            • Harmon C.
              • August 31, 1994
              • 3228
              Nice job. Four weeks for 8 judging points. 416 per year. For 4500 points this could be a 11 year restoration. That may not be the record.
              Lyle
                • 15602
                I have seen that Dychem layout fluid at a nuts & bolts store -- Fastenall I believe is the name, although I may have the spelling wrong. There is also a mail order source, but I usually pitch their catalogs, so I don't have a name at the moment.
                BTW: The red version of this stuff works for the red dot on early C3 headlamp actuators. Much better looking than paint for the application.
                • Stephen B.
                  • April 1, 1988
                  • 876
                  This time I put a heavy coat of layout fluid on the strut rods. They definitely are blue.
                    • 15602
                    Steve, there was a thread within the last month or two in which someone posted a picture of a Pitman arm that has the most gorgeous as forged finish I have seen since I worked in a metallurgy laboratory. I wish I would have saved that image. I hope someone can find it for us.
                    • Stephen B.
                      • April 1, 1988
                      • 876
                      Terry,
                      I'll look for the picture. Do you think the finish is too blue? I can tone the blue down with rubbing them with laquer thinner.
                      • Gary B.
                        • February 1, 1997
                        • 7024
                        Pitman arm photo
                        Terry,
                        Any idea who posted that photo? I'd like to take a look, but I can't find it in the archives.
                        Gary
                        • Stephen B.
                          • April 1, 1988
                          • 876
                          Here's a link to a drag link for a straight axle. Good photo.
                          https://www.forums.ncrs.org/showthre...itman&uid=9604
                            • 15602
                            That's it Steve.
                            All the C1 suspension parts look alike to me.
                            The first three pictures, and especially the second one show the as forged finish. That blotchy look is the give away. It is splotchy because some of the scale falls off the hot piece as it is handled.
                            • Gary B.
                              • February 1, 1997
                              • 7024
                              That blotchy look
                              Terry,
                              I imagine that blotchy appearance would be very difficult to duplicate without actually going thru the forging step.
                              Gary
